This module can be used on every arduino mega ramps 1.4.
with Marlin version.
Updated :
  • Arduino Mega 2560 + RAMPS + 4 x A4988
  • LM4UU Bearing (Smoother movement)
  • 2GT 16 tooth Gear (Easy Setting from Marlin)
  • GT2 Belt
  • 2004 LED Display /with jgaurora Logo (Display Info)
  • SD Card Module (Offline Printing)
  • 4mm Thickness Metal Case (Stable Support)
  • 4 x 42 Stepper 0.8 degree per step (Stable Movement)
  • Bed Leveling using sping
The maximum size of printed object is 20 x 18 x 18cm , which is relatively equal to many other prusa i3 3D printer.
The gain from the trade off is the cost down of material and maintenance. Take out components for making large printed object , the design become simple and lean. The core material is metal sheet and connected by metal screw. Therefore , the cost of material and building can be minimized.
Easy to build / Learning by making
The process of making has the opportunity to transform education by inviting students to be something other than consumers of education. They can be maker of anything , moving from being directed to self-directed through the process.
JGAURORA is designed for easy to build. The assemble from kit can be done by just using a screw driver. We wish student can make their own machine. Then they become a pioneer whose may make another one for other people. So that the use of 3D printer can be spread out to more student.
Specification
Size: 43cm(W) x 40cm(D) x 41cm(H) (excl. filament holder)
Printed size : 20cm x 18cm x18cm
1.75mm filament / 0.4mm hotend
