Hi when i select auto home only one motor moves and the others do no, I linked a youtube video with the problem. Please HELP!
Hi @Nawrocki, you might be able to find the solution in this thread. Another Kossel Delta owner was facing similar issues.
You should probably check your toothed roller attached to the spindle of your stepper motors. If they are too close to the motor, they tend to cease moving. You should loosen the 2 motors or even the one that moves and give the toothed roller some distance from the motor housing. Hope this helps!
Please help! I’m having the same issue and the thread is broken. Any solutions?
Can you refind this thread? I’m having the exact same issue
