I’ve had a build suddenly stop with an error message
Stopped by Embedded
I’ve shut it all down and restarted the build but getting the error message again.
I tried a head clean to get the heads back to their home position and then get the following:
Wizard performing purge throw exception: runtime error: GetTAxisState mode didn’t get ack for message
Thread serial receiver 1 throw exception: Motor_T: wrong state: 0, (code 0)
Wizard clean heads wizard throw exception: runtime error: set motor mode didn’t get ack for message.
Started the build again and now getting this error message just after the UV light is switching on:
Pre-Print error – MCB wrong position Received (-10056) end print.
Has anyone seen this before or now what the problem could be?
Any help much appreciated please.
Many thanks
Adam
