My Raise3d N2 Plus glass bed doesn’t stay secure.
Hey, guys, I have been running many prints on my Raise3d N2 Plus, but I have had a couple of failed prints where the bed comes off the bed, even though I am using Binder Clips. Help would be appreciated.
Thanks,
Arjun
Are the parts maybe sticking too well to the glass or buildtak? Does the printer hit the part which then causes the glass plate to pop off?
i have the same exact 3D printer and have had the same issue before. How I resolved it was added two more binder clips to the side. Its alittle frustrating putting them on but it has kept it from moving anymore.
I realize its not a high tech fix but it works
I’m assuming your entire build plate shifted though. Thats what happened it my case
Yes, my entire plate shifted, I will try 2 more binder clips and let you know how it works.
Attached is how I have my setup
Thank you so much, this helps a lot.
glad it worked out for you
