hello,
I’ve published a 3d print project on thingiverse, for a solid enclosure for DFRobotics SEN 0193, a capacitive soil moisture sensor I’m using for a watering system based on Arduino (the prototype used resistive ones).
did anyone had a similar need already, and came to something similar?
cheers
corrado
Interesting, I am just about to do a enclosure for my own soil moisture meter with in built probe and display, so while looks good, prob not an exact fit for me at the moment
hi,
I shared both versions as CC-SA-NC-BY:
you should now be able to start from it and change it as you need it.
cheers
corrado
I should have replied here…
see post above, the sketches are open to mods now
Hi corrado,
I am looking for the plastic enclosure material for soil moisture sensor…can you suggest me the suitable one…this sensor will be used in Container Farming.
thanks,
SunilM
