The Mohtherboard was bought aftermarket, but it is the same, even the Network Card is the same model. I have tried to connect printer to the switch by the normal Ethernet Cable. When I made it the printer starts normal. But later when I connect PC to the same switch, the printer stops, even the front panel stops to work (I can only switch off the printer by the power button). The IP setup is configured static IP acording to the manual instruction. The PC and Printer has diferent IP adress. Do you have any other idea what is wrong?
