1. 3D printing
  2. High flexibility
High flexibility
Highly flexible rubber-like materials that have elongation at break greater than 50%.
SLS High flexibility Materials
SLS is used for both prototyping and small-batch production of functional plastic parts with good mechanical properties.
Benefits and Limitations
Longer lead times than FDM
Price $$$$$ Tolerance ± 0.3% (min: ± 0.3 mm)
Turnaround time < 5 days Wall thickness 0.7 mm
Max part size 75 x 55 x 55 cm Layer height 80 - 120 μm
Standard TPU
TPU (SLS) is an elastomer with good tear resistance and shore hardness of 45D that is suitable for durable parts with rubber-like properties.
Material family
FDM High flexibility Materials
Fast turnaround times
Standard TPU
TPU (FDM) is a rubber-like, flexible elastomer with shore hardness 60A - 95A that can bend and compress. Lacks the performance of true rubber.
Material family
