CNC-milling
CNC Milling Service
Our CNC milling service capabilities
From prototyping to full production runs. Our 3 axis, 3+2 axis and full 5-axis milling centers will allow you to produce highly accurate and quality parts to meet even your most stringent requirements.
Can’t decide if 3-axis, 3+2-axis or full 5-axis machining is best for you? Upload your CAD file for a free quote and manufacturability review that will identify any difficult-to-mill features.
3-axis and 3+2-axis CNC milling
3-axis and 3+2 axis CNC milling machines have the lowest start-up machining costs. They are used to produce parts with relatively simple geometries.
Maximum part size for 3-axis and 3+2-axis CNC milling
Size Metric units Imperial units
Max. part size for soft metals [1] & plastics 2000 x 1500 x 200 mm
1500 x 800 x 500 mm
78.7 x 59.0 x 7.8 in
59.0 x 31.4 x 27.5 in
Max. part for hard metals [2] 1200 x 800 x 500 mm 47.2 x 31.4 x 19.6 in
Min. feature size Ø 0.50 mm Ø 0.019 in
[1] : Aluminum, copper & brass [2] : Stainless steel, tool steel, alloy steel & mild steel
Max. part size for soft metals [1] & plastics 2000 x 1500 x 200 mm 78.7 x 59.0 x 7.8 in
5-axis CNC milling
5-axis CNC milling centers can produce parts with complex geometries and increase productivity by minimizing the number of machine setups.
cnc-5-axis machine
Maximum part size for 5-axis CNC milling
Max. part size for all materials 650 x 650 x 300 mm 25.5 x 25.5 x 11.8 in
Available materials for CNC machining
Here is a list of our standard CNC machining materials available through our online platform.
CNC Metals
Aluminum Stainless steel Mild, Alloy & Tool steel Other metal
6061-T6 303 Mild steel 1018 Brass C360
6082 304 Mild steel 1045 Copper C101
7075-T6 316L Mild steel A36 Copper C110
5083 2205 Duplex Alloy steel 4140 Titanium Grade 1
5052 17-4 Alloy steel 4340 Titanium Grade 2
2014 15-5 Tool steel O1 Invar
2017 416 Tool Steel A2 Inconel 718
6063 420 Tool Steel A3 Magnesium AZ31B
7050 430 Tool Steel D2
A380 440C Tool Steel S7
MIC 6 301 Tool Steel H13
CNC Plastics
Plastics Reinforced Plastic
ABS Garolite G-10
Polypropylene Polypropylene (PP) 30%GF
Nylon 6 Nylon 30%GF
Delrin (POM-H) FR4
Acetal (POM-C)
PVC
HDPE
UHMWPE
Polycarbonate
PET
PTFE (Teflon)
Available surface finishes for CNC machining
Surface finishes are applied after machining and can change the appearance, surface roughness, hardness and chemical resistance of the produced parts.
  Name Description
cnc-surface finish-as-machined-1 As Machined (standard) ~125 RA µin (3.2 RA µm). Minor tool marks will be visible on the part.
cnc-surface-smoothed Smoothed Parts are machined at a lower feed rate in order to achieve a surface roughness of ~62.5 RA µin (1.6 RA µm). Surface roughness can be decreased up to ~32 RA µin (0.8RAµm) upon request.
cnc-surface finish-bead blasted-1 Bead Blasted Bead blasting adds a uniform matte or satin surface finish on a machined part, removing all tool marks. Mainly used for aesthetic purposes.
cnc-surface finish-anodized-1 Anodized Clear or Color (type II) Anodizing adds a thin, hard, non-conductive ceramic coating on the surface of aluminum parts, increasing their corrosion and wear resistance. Available in a variety of colors.
cnc-surface finish-anodized-2 Anodized Hardcoat (type III) Hardcoat anodizing produces a thicker ceramic coating providing excellent corrosion and wear resistance. for functional applications.
cnc-surface finish-powder coating-3 Powder Coated Powder coating adds a thin layer of strong, wear and corrosion resistant protective polymer paint on the surface of a part. Available in a large range of colors.
electropolishing (temporary) Electropolished Electropolishing is an electrochemical process used to polish, passivate and deburr metal parts. It is useful to reduce surface surface roughness.
Black oxide (stock photo) Black oxide Black oxide is a conversion coating used to improve corrosion resistance and minimize light reflection.
chromate_conversion (stock photo) Chromate conversion coating (Alodine/Chemfilm) Chromate conversion coating is used to increase the corrosion resistance of metal alloys while maintaining their conductive properties.
brushed finish Brushing Brushing is produced by polishing the metal with grit resulting in a unidirectional satin finish.
Other surface finishes are also available. Learn more about our metal and plastic surface finishing capabilities here.
The table below summarizes the standard tolerances of the parts produced by certified 3D Hubs Manufacturing Partners. Tolerances up to .0008” (0.020mm) are available upon request.
Part size / Dimension Tolerance Angularity
< 12’’ (300 mm) ± .005’’ (0.125 mm) ± 0.5°
< 24’’ (600 mm) ± .010’’ (0.250 mm) ± 1.0°
< 36’’ (900 mm) ± 1/64’’ (0.400 mm) ± 1.0°
Tightest tolerance: ±.0008’’ (0.020 mm) Tighter tolerances are examined on a case by case basis with your technical drawings.
CNC milling design guidelines
The table below summarizes the recommended and technically feasible values for the most common features encountered in CNC machined parts.
  Feature Recommended size Feasible size
cnc-illustration-SMALL FEATURES Min. feature size Ø 2.5 mm Ø 0.50 mm
cnc-illustration-INTERNAL EDGE Internal edges R 8 mm R 0.25 mm
cnc-illustration-MINIMUM WALL THICKNESS Minimum wall thickness 0.8 mm (for metals)
1.5 mm (for plastics)
0.5 mm (for metals)
1.0 mm (for plastics)
cnc-illustration-DRILLING Holes Diameter:standard drill bit sizes
Depth: 4 x diameter
Diameter: Ø 0.5 Depth: 10 x diameter
cnc-illustration-THREADS Threads Size: M6 or larger
Length: 3 x diameter
Learn more in our Engineering Guide to CNC machining.
Quality assurance
  • ISO9001 certified Manufacturing Partners on request
  • Inspection report included in every order. Full dimensional inspection reports on request
  • Material certifications and test reports available on request
  • Batch inspection in concurrence with ISO2859
  • Strict NDA agreements with all Manufacturing Partners
  • Manufacturing Partner performance tracking on lead time and quality
Inspection-checklist
Matt Farr, UK Strategic Account Manager Alex Vermolen Director of Sales EMEA
Jennifer Kaari, US Strategic Account Manager Jennifer Kaari US Strategic Account Manager
For businesses of all sizes
Get in touch with our team to access these services:
  • Add 3D Hubs as a vendor
  • ISO 9001, material certifications, test reports and full dimensional reports
  • Urethane casting and part marking
  • Sample verification program (learn more)
Call us directly on , or email us at sales@3dhubs.com
Get your parts CNC milled in as fast as 5 days
Upload your designs and get instant feedback on manufacturability, suggesting the best process based on your parts design.
calendar-lead-time
