3D printing service Green Bay, WI
FDM 3D Printing service in Green Bay, WI
SLS 3D Printing service in Green Bay, WI
MJF 3D Printing service in Green Bay, WI
SLA 3D Printing service in Green Bay, WI
Over 227 customers are satisfied with our 3D printing service.
“This is my first time requesting any type of 3d printing. I will extremely pleased with the communication, speed of service and the print quality of my order and parts requested. Will definitely use this service again....when needed.”
Ryan, Oshkosh
“Very helpful and fast! Also warns of possible errors before the print and gives helpful tips on how to improve part on your own.”
Kaden, mt. calvary
“Very nice part. The bed side finish is very nice. I hope to order more parts soon. ”
Dean, New London
“This was my first print, and while I'll improve on the modeling next time, the parts I ordered turned out exactly as modeled and ordered. Very happy with the communications (including the jpgs of the finished parts) and the overall turnaround.”
Keith, Glendale
“Great communication. Good looking parts.”
Joseph, Milwaukee
Standard TPU, SLS
“Excellent service. I am new to the process and still learning. Thanks for the great experience. ”
John, Hartland
Standard PETG, FDM
“Great Experience, fast print and delivery, would work with anytime.”
Ryan, Milwaukee
“Parts turned out great and were finished and arrived very quickly! Thank you! ”
Austin, Oconomowoc
“There was a slight flaw in my design that resulted in a small ring around one edge of the print that wasn't suppose to be there. They took the extra time to tweak the STL so it would not print the ring. My print was just a simple little adapter piece and the cosmetics didn't matter to me but it was great they made the effort to maximize the quality of the print. I will definitely be using them again for future prints.”
Eric, Greenfield
“Would be very pleased to work with this provider again.”
Adrian, South Milwaukee
Standard Nylon, SLS
“Very fast communication and very informative and considerate of my needs”
Hamilton, Wausau
“Excellent production and service. Parts look outstanding. Looking forward to future business!”
james, FRANKFORT
Standard Nylon, SLS
“My order turned out perfect. Awesome service, awesome quality. ”
Ben, DeForest
Standard ASA, FDM
“Product is high quality and was completed very quickly”
Aaron, Kenosha
Standard resin, SLA/DLP
“Good communication and arrived in great condition ”
Sophia, Madison
Standard TPU, FDM
“Excellent quality print that arrived faster than expected.”
Carl, North Chicago
“wow. the parts were way better than expected. Thanks!”
Eric, Grand Haven
“Good communication, flexibility, and print quality. Well done. ”
Donald, spring lake
“Parts are in printed to specifications and service was prompt and dependable. Thanks ”
Hugh, Crystal Lake
“Very happy with the product and the service”
Israel, Highland Park
“Great service. Quality product. Quick turn around. Well informed updates. No complaints.”
Jake, Traverse City
“Quickly responded to questions and followed up well”
David, Northbrook
“Awesome. Really happy with my first 3D print”
Tim, Arlington Heights
“Great! A lot of professional communication. Smooth process. Everything as expected. I would love to work with them again!”
Trent, Belvidere
“I had a fairly large and complex order and everything was delivered as expected with great prints.”
Robert, Carpentersville
Standard PETG, FDM
