3D printing service Milton Keynes
FDM 3D Printing service in Milton Keynes
SLS 3D Printing service in Milton Keynes
MJF 3D Printing service in Milton Keynes
SLA 3D Printing service in Milton Keynes
Over 218 customers are satisfied with our 3D printing service.
“Thank you - you were very helpful to this 3D-printing novice, and went the extra mile to ensure everything was OK, even though I'd placed a less-than-perfect order. Communication, service and speed were excellent, and I can't fault anything. The next time I need anything printed, I'll go to the same place.”
Jeffery, Milton Keynes
“Great in every way. Communicated almost instantly. Part is great. Will use again.”
Richard, Wolverton
“Nice, limiting factor was my 3d model, print was perfect.”
Jake, Bedford
Standard resin, SLA/DLP
“Really simple and fast process. Excellent end results. ”
Gareth, Tring
“Great to see these results, thanks for a super print”
Elizabeth, Aylesbury
“Thank you for the extra speedy service on this one!”
Sarah, Aylesbury
“Speedy service, will use again. Good quality product.”
Stephanie, STUDHAM
“Good print quality and arrived in 2 days. Thank you.”
Peter, STUDHAM
“delivered before the shipped date, it was that fast...”
James, Northampton
“this wook mix material is really cool - finish is at a good qualirt to bring out the details :-) Very fast service and high quality :-)”
Eli, Wendover
Woodfill PLA, FDM
“Many thanks, the part works perfectly and the quality was better than i expected considering the price :) If i need anything done in future i know where my first port of call will be”
Shane, Wellingborough
“Parts came prompt - never used 3d printing service before - will use again”
Andrew, Luton
“Superb above and beyond service, thanks very much!”
Simon, Chesham
Standard PETG, FDM
“Very quick deliver, excellent print quality - many thanks!”
Gavin, Chesham
“Great prints and a friendly serivce thanks ”
Glen, Hemel Hempstead
Standard PETG, FDM
“Amazing service, super fast, great job! Thanks.”
Mark, High Wycombe
Standard PETG, FDM
“Great print, and posted very fast.. Would highly recommend!”
Sultan, Kettering
Standard TPU, FDM
“Excellent service, great quality and fast turn around!”
peter, Hemel Hempstead
“Ordered on the 8th, expected on the 14th. Actually arrived on the 9th, next day. Pretty amazing!”
Samuel, Hemel Hempstead
“Great fast and high quality service, friendly, helpful and very communicative. Would definitely use again.”
Zeph, Kings Langley, Hertfordshire
“Lovey service! There was an issue with my original design, this was promptly highlighted and a reprint was made. Would strongly recommend! Many thanks!”
Mario, Hitchin
“Excellent - prompt efficient service - recommended”
ian, Bourne End
“Great service. Product printed very quickly and great quality. Highly recommend. ”
Matthew, St Albans
“Great service and excellent print quality...many thanks.”
Richard, Letchworth Garden City
Standard PETG, FDM
“Quality part, early delivery. Would use again.”
Trevor, St Albans
