Post-processes & finishes
Material choice, post-processing and surface finishing can make all the difference in manufacturing. Processes like cleaning, curing, polishing and dyeing improve the cosmetic and functional qualities of 3D printed parts. And for CNC machining, anodizing, powder coating and electroless nickel plating impact a part's appearance, strength, electrical conductivity and more. Find out more about the various materials used in manufacturing and explore how post-processing and surface finishing work.
What is powder coating? Surface finishes for CNC machining
What is powder coating and in what cases should you select it as a finish for CNC-machined metal parts? This article covers the details of the powder coating process, as well as when to choose it for the best performance and quality.
What is anodizing and how does it work?
What is anodizing? Anodizing is key to finishing parts made from aluminum and other metals. Learn how anodizing works and why it is an important part of CNC machining and manufacturing.
Post processing for FDM printed parts
A comprehensive guide describing the range of post-processing options for FDM printed parts
Post processing for SLA printed parts
A comprehensive guide describing the range of post-processing options for SLA printed parts
Post processing for SLS printed parts
Post-processing for SLS and MJF 3D printed parts
What are the post-processing methods and steps for SLS and MJF 3D printing? In this article, we explore the most common post-processing methods, including dyeing and metal plating.
Example of a black oxide part in mild steel
What is black oxide coating?
Want to learn more about black oxide coating? In this article, we’ll take a look at black oxide as a surface finish, its history, common applications, and more
What is media blasting and how does it work?
Want to learn about media blasting? Here’s a guide to using the post-processing technique, how it works, its common industrial uses, and more.
How to improve the aesthetics of parts
Find out about the range of surface finishes and materials that make for aesthetically pleasing custom parts.
Type II vs Type III anodizing: what does your project require?
Learn about the differences between Type II and Type III anodizing, their benefits, typical applications, and how to choose the ideal surface finish for your part.
What is passivation?
Passivation is a chemical process used to enhance the corrosion resistance and durability of a metal. Find out how it works and when it’s a worthwhile addition to your custom parts.
