3D printing service San Diego, CA
FDM 3D Printing service in San Diego, CA
SLS 3D Printing service in San Diego, CA
MJF 3D Printing service in San Diego, CA
SLA 3D Printing service in San Diego, CA
Over 161 customers are satisfied with our 3D printing service.
“Great service. Fast turn around and shipping.”
Dion, San Diego
“Couldn't ask for better service or product. Great communication. Worked with me in selecting a suitable material. Fast turnaround. ”
Dan, San Diego
Tough resin (ABS-like), SLA/DLP
“Excellent service and hugy knowledgeable. ”
A.E., San Diego
Heat resistant resin, SLA/DLP
“Can't believe how quick this was!! A+ Thank you!”
james, San Diego
“excellent parts fast turn around and very good pricing.”
Paul, La Jolla
Standard resin, SLA/DLP
“Great looking parts done in a timely manner.”
Brian, La Jolla
“very good prints, great communications and very fast prints”
Omar, San Diego
Standard PETG, FDM
“Awesome job! Pieces turned out great, nice work :D”
Avery, San Diego
“Great parts, fast shipping. Great quality ”
Jose, San Diego
“The print quality was precise and turnaround time was fast!”
Holden, Coronado
Standard Nylon, SLS
“great 3D printing service meets the expectations.”
vicente, Chula Vista
Standard TPU, FDM
“Better than expected quality. Great service.”
Justin, Chula Vista
“Great communication. Fast printing and delivery. Great quality. Thank you !”
othello, chula vista
Standard ASA, FDM
“Amazing quality for the best affordable Price. Communication was great and professionalism was perfect. Parts arrived sooner than expected. ”
Arturo, San Diego
“Same day print and real time feed back. Excellent job”
James, Carlsbad
“The company is great.. I'm planning on making many more purchase orders!”
Kevin, San Marcos
Carbon-fiber reinforced Nylon, FDM
“5 star service. Fast response, great print quality, and quick turn around. Thank you. ”
Kai, Carlsbad
“Parts look great and were delivered early.”
Chris, Carlsbad
Standard Nylon, SLS
“First time having an item 3D printed. Truly amazed with the quality of the items I received!”
Kenneth, Oceanside
Standard Nylon, SLS
“Great service and quality. Would use again.”
Martin, Temecula
“Great print that came with great customer service.”
Bo, Laguna Niguel
“Amazing quality, and delivered in just a few days!”
Steven, MENIFEE
“Excellent service. Very fast and high-quality results.”
Eileen, Laguna Niguel
“Fast service and parts came out great! Thank you! ”
Kevin, Hemet
Standard Nylon, SLS
“service was awesome, lots of communication and updates. nice quality”
Aaron, Perris
