Looks very promising! 3 questions:
1) LokBuild makes prints stick the right amount regardless of temperature and nozzle height, it’s adhesion is much more independent of height than other print surfaces, right? I love the idea of minimizing that little “flare” (added edge) and incorrect height caused by the squishing required on other surfaces. However, this also means that if it sticks too much, it will ALWAYS stick too much. How do you remove prints, especially if they are stuck because of a high contact area? What if print has small contact area and needs additional adhesion - other surfaces can be increased with a lower nozzle height, but LokBuild is independent of height, so how is adhesion modulated?
2) Why does shipping add up linearly on your site, versus initial packaging charge plus a per-weight charge? I would expect adding 1 small size to 1 large size would add at most 1.00 to shipping, not 6.00. Kickstarter even shows no added shipping cost for additional pieces, and 5 pieces add only 4.00 above 1-piece shipping, akin to 5.00 fixed + 1.00@ (for small).
3) Delivery for current (Nov 2016) orders is still February 2017?
