The Protolabs Network Standard
Non standard features requirements
Sharp corners
Internal sharp corners require EDM machining and increase significantly machining costs, therefore they should be avoided as much as possible. Most of the time, when sharp corners are requested, the supplier will suggest changes that will make the part easier to machine.
Here is the order of options considered when sharp corners are present on the CAD model:
Increasing the radii
A radius of at least 1/4 of the pocket depth can be suggested
For example, this pocket is 10mm deep, at least 2.5mm radius will be suggested.
"Dog bones" fillet can be suggested
EDM (sinking EDM or wire-EDM): EDM should only be reserved for the cases where the sharp corners are absolutely indispensable. It will significantly increase machining costs.
Knurling
When knurling is needed, it needs to be mentioned on a technical drawing.
  • If there is no mention of a standard, either DIN82, ISO13444:2012 will be followed by default
  • If another standard is mentioned, it will only be accepted if it can be fulfilled by our network. In the opposite case a known standards will be suggested to you.
Part marking
We offer laser engraving and silk screening on demand
Name Laser engraving Silk screening
Additional price +10% +20%
Additional lead time + 1 day +1-3 days
Specifications Depth: 0.08mm to 0.5mm
Paint infill possible
n/a
Documentation required Vector file (AI, CorelDRAW, Autocad, DXF) PDF with exact positioning of marking Vector file (AI, CorelDRAW, Autocad, DXF) PDF with exact positioning of marking
