FDM 3D printing service
Source high-performing parts for rapid prototyping and low-volume industrial production with FDM 3D printing. We offer FDM for quick-turn manufacturing using a variety of robust materials for many use cases and can print parts in 1 day.
Get instant FDM quote
Manufacturing with FDM 3D printing
FDM (fused deposition modeling) 3D printing creates custom parts by heating and extruding thermoplastics layer-by-layer. You can use FDM for initial and functional prototyping and low volume production in a variety of strong plastic materials. While FDM is the most affordable 3D printing technology, it’s far more than a small-scale manufacturing solution. 3D printing with FDM means getting access to thermoplastics, including PLA, ABS, TPU, PETG and PEI, and a dimensional accuracy of ±0.5% with a lower limit of ±0.5 mm (0.0196”).
Learn more about FDM 3D printing
Fused Deposition Modeling (FDM) capabilities
FDM 3D printing has two distinct classes: prototyping (desktop) FDM and industrial FDM. These are the key capabilities of both technologies.
Maximum build size Standard lead time Dimensional accuracy Layer height Infill
Prototyping FDM 500 x 500 x 500 mm (19.68 in x 19.68 in x 19.68 in) From 2 business days ± 0.5% with a lower limit on ± 0.5 mm (0.0196 in) 100-300 μm 20-80%
Industrial FDM 406 x 355 x 406 mm* (15.98 x 13.97 x 15.98 in) 3 business days ± 0.3% with a lower limit of ± 0.3 mm (± 0.012") 100-300 μm Ultra-light, Light, Solid
Materials available for FDM 3D printing
Examples of available materials for FDM 3D printing
Prototyping FDM materials
Ideal for fast and affordable rapid prototyping and modeling.
Prototyping PLA
Prototyping PETG
Prototyping ASA
Prototyping ABS
Prototyping TPU
Example of industrial materials available for FDM 3D printing
Industrial FDM materials
Ideal for higher-volume production and bigger parts with better mechanical properties.
Nylon: Markforged Onyx
PEI: ULTEM 9085, ULTEM 1010
ASA: Stratasys ASA
ABS: ABS M30, ABSplus
Comparing FDM to other 3D printing processes
Materials Price Dimensional accuracy Strengths Build volume Layer thickness Min. feature size
FDM 5 $ ± 0.5% with a lower limit on ± 0.5 mm Low cost, wide range of materials 500 x 500 x 500 mm (19.68" x 19.68" x 19.68") 100-300μm 2.0 mm (0.0787’')
Industrial FDM 6 $$$$ ± 0.3% with a lower limit of ± 0.3 mm (± 0.012") High level of repeatability, engineering grade materials 406 x 355 x 406 mm (15.98” x 13.97” x 15.98") 100-330μm 2.0 mm (0.0787’')
Prototyping SLA 8 $$ ± 0.3% with a lower limit of ± 0.3 mm (± 0.012") Smooth surface finish, fine feature details 145 × 145 × 175 mm (5.7" x 5.7" x 6.8") 50-100μm 0.2 mm (0.00787’')
Industrial SLA 3 $$$ ± 0.2% with a lower limit of ± 0.13 mm (± 0.005") Smooth surface finish, fine feature details, big print area 500 x 500 x 500 mm (19.68" x 19.68" x 19.68") 50-100μm 0.2 mm (0.00787’')
SLS 2 $$ ± 0.3% with a lower limit of ± 0.3 mm (± 0.012”) Design flexibility, supports not required 395 x 500 x 395 mm (15.53" x 19.68" x 15.53") 100μm 0.5 mm (0.0196”)
MJF 2 $$ ± 0.3% with a lower limit on ± 0.3 mm (0.012’') Design flexibility, supports not required 380 x 285 x 380 mm (14.9’’ x 11.2’’ x 14.9’') 80μm 0.5 mm (0.0196”)
We have high standards for FDM 3D printing
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to The Protolabs Network Standard. A thorough verification of these requirements is included in our inspection report that we ship with every order.
  • Consistent surface finish with no bumps or delamination. Marks left by retraction and layer changing are acceptable.
  • All support material is removed so that the supported surface has a consistent finish.
  • All parts are printed with 3 outline / perimeter shells or a wall thickness of 1.2 mm.
Advantages and drawbacks of FDM 3D printing
Advantages of FDM printing
Advantages
  • FDM is the most cost-effective way to produce custom thermoplastic parts and prototypes.
  • Lead times are short (typically a few days).
  • A wide range of materials is available, suitable for prototyping and industrial applications.
Drawbacks of FDM process
Drawbacks
  • FDM is not suitable for parts with very small details due to its low resolution.
  • Parts are likely to have visible layer lines, so post-processing is required for a smooth finish.
  • The layer adhesion mechanism makes parts inherently anisotropic.
Design guidelines for FDM
The table summarizes the recommended and technically feasible values for the most common features encountered in FDM 3D printed parts.
Learn more about how to design parts for FDM 3D printing
Feature Recommended size
Unsupported walls 0.8 mm (0.0315 in)
Supported walls 0.8 mm (0.0315 in)
Minimum feature size 2.0 mm (0.0787 in)
Minimum hole diameter 2.0 mm (0.0787 in)
More resources for FDM 3D printing
Learn more about how FDM 3D printing works and how to design the best parts for this additive manufacturing technology.
Our other 3D printing processes
Dimensional accuracy of ± 0.3% with a lower limit of ± 0.3 mm (± 0.012")
