1. 3D printing
  2. Material Jetting
Material Jetting
Material Jetting produces parts of the highest dimensional accuracy with very smooth surface finish, used for both visual prototypes and tooling manufacturing.
Benefits and Limitations
Smooth, injection molding-like finish
Brittle, not recomemended for functional parts
Price $$$$$ Tolerance ± 0.1% (min: ± 0.05 mm)
Turnaround time < 5 days Wall thickness 1.0 mm
Max part size 100 x 80 x 50 cm Layer height 16 - 32 μm
Material Jetting Resin Materials
High detail and smooth surface, injection mold-like prototyping.
Standard resin
Standard Resin (Material Jetting) produces extreme detail, rigid, injection mold-like parts with a smooth surface. Used for top-end visual, non-functional prototyping.
Material family
Digital ABS
Digital ABS (Material Jetting) mimics the properties of ABS and produces stiff, rigid parts for engineering applications. Greater detail than Tough Resin (SLA).
Material family
Durable resin (PP-like)
Durable resin (Material Jetting) mimics the properties of PP and is semi-flexible. Ideal for durable, high-detail prototypes. Greater detail than Durable Resin (SLA).
Material family
Transparent resin
Transparent resin (Material Jetting) has a completely 100% clear, glass-like appearance and is ideal for prototypes that resemble real injection molded parts.
Material family
Rubber-like resin
Rubber-like resin (Material Jetting) produces high-detail parts with a soft rubber-like appearance and shore hardness < 70A. Not suitable for functional prototypes.
Material family
Heat resistant resin
Heat resistant resin (Material Jetting) has high strength and heat deflection temperature and can be used to produce high detail, low-run injection molds.
Material family
Castable resin
Castable resins (Material Jetting) are high detail resins for investment casting pattern making. No residue after burn out. Greater detail than Castable Resin (SLA).
Material family
Dental resin
Dental resins (Material Jetting) are high detail, sterilizable and biocompatible resins suitable for dental implants. Greater detail than Castable Resin (SLA).
Material family
