CNC part for The Phased Array Company (TPAC)
Online CNC machining service
Benefit from competitive pricing through our network of 187 verified CNC machining services
3D Hubs is rated 4,8/5 based on 165,939 customer reviews
Portrait of Grafton Montgomery from The Phased Array Company (TPAC)
Reduced time to market
Grafton Montgomery - The Phased Array Company (TPAC)
Using 3D Hubs has enabled us to quickly source short run CNC parts, resulting in a significantly reduced time to market. The parts are always perfect, timely and reasonably priced. We are big fans!
Explore our CNC machining materials
Find the right material for your project. See all metals and plastics or filter by a specific property.
Metals
Our most popular CNC machining metals.
High machinability and ductility, good strength-to-weight ratio.
Stainless steel
High tensile strength, corrosion and temperature resistant.
Brass
Low friction, excellent electrical conductivity, golden appearance.
Plastics
Our most popular CNC machining plastics.
Common thermoplastic, impact resistant, easy to machine.
Polycarbonate
High toughness, excellent impact strength, transparent.
Excellent mechanical properties, thermal, chemical and abrasion resistant.
CNC machining surface finishes
As Machined (standard) ~125 RA µin (3.2 RA µm). Minor tool marks will be visible on the part. Surface finish requirements can be increased to 63, 32, or 16 RA µin.
Bead Blast Matte finish with light texture is achieved by blowing small glass beads against the part.
Anodizing Type II Corrosion resistant finish. A variety of different colors can be applied when anodizing.
Anodizing Type III Adds a wear resistant layer on top of the corrosion resistance of Type II.
Powder Coat Strong, wear and corrosion resistant finish, that is more durable than the methods mentioned above. Powder coat finishing are available in large range of colors.
Other surface finishes are available upon request
Sample CNC machined parts
Click on the images to learn more about the tools, materials and finishing used.
Ready to CNC machine your parts?
Upload your parts, select quantity, material and finish to receive a free quote within the next 24 hours.
How to produce custom metal parts
for your business
Learn how to select the right manufacturing process for your metal parts. Our free Metal Kit helps you easily compare CNC machining and additive manufacturing (AM) technologies.
Producing metal parts - 3D Hubs Metal Kit
