3D Printing vs. CNC machining
CNC machining is one of the most common subtractive manufacturing technologies. It uses a variety of rotating tools and cutters to transform a solid block of raw material—this is called a blank—into nearly finished components.
For both small one-off jobs and medium to high-volume production, CNC machining is one of the most popular methods of manufacturing. It offers excellent repeatability, high accuracy and a wide range of materials, post-processing options and surface finishes.
Upload your design for a free, instant quote
Basic schematic of the CNC process in action
3D printing (3DP), which falls under the umbrella of additive manufacturing (AM), builds parts one layer at a time. 3D printing and other AM processes don’t require special tooling or fixtures, so the initial setup cost is minimal compared to CNC machining.
Basic schematic of the 3D printing process in action
While the two technologies are quite different in how they work, there is a lot more overlap in how they’re applied than you might think, especially when it comes to prototypes and functional end-use parts (made from plastics and metals).
In this article, we cover the key technology considerations to help you choose the right technology for your custom part needs.
3DP vs CNC: How do you choose the right manufacturing technology?
There are a ton of factors to consider when choosing the optimal manufacturing technology for your specific applications. Luckily, we’ve devised a few simple guidelines for selecting either 3D printing or CNC machining (or both in some cases).
As a rule of thumb, all parts that can be manufactured with limited effort through a subtractive process should generally be made with CNC machining.
CNC machining offers greater dimensional accuracy than 3D printing (this may change with further innovations to AM) and produces parts with better mechanical properties in all three dimensions. However, CNC machining usually comes with a higher price tag, especially with smaller volumes of parts.
3D printing is optimal in these situations (among many others):
  • When traditional methods are not able to produce the part efficiently or cost-effectively, or even at all. This occurs when you have highly complex, topology-optimized geometries, for example.
  • When a fast turnaround time is critical. 3D-printed parts can be delivered within 24 hours.
  • When you’re on a budget. 3D printing is generally cheaper than CNC machining for small volumes.
  • When you need a small number of identical parts (fewer than 10).
  • When your parts require materials that can’t be easily machined, like metal superalloys or flexible TPU.
If you need to produce higher quantities of parts—hundreds or even thousands of individual components—then neither 3D printing or CNC machining may be the most viable option. Traditional forming technologies, like injection molding, are generally the most economical way to produce parts at scale.
The total number of required parts is a key design consideration when selecting a manufacturing technology
How many parts are you manufacturing? Choosing 3D printing or CNC machining
The number of parts you plan to produce will play an important role in your final decision between 3D printing or CNC machining. In the table below, we break this down by the number of parts, materials and part geometry. Aside from our principal recommendations, we also include alternative options.
Number of parts 1-10 10-100 100-1000 1000+
Plastic 3D printing 3D printing (consider CNC) CNC machining (consider injection molding) Inection molding
Metal 3D printing & CNC machining* CNC machining (consider 3D printing) CNC machining (consider investment casting) Investment or die casting
*this is highly dependent on part geometry
Does 3D printing or CNC machining offer better dimensional accuracy?
CNC machining offers tight tolerance and excellent repeatability. Very large to very small parts can be CNC machined accurately. Thanks to the shape of most cutting tools, internal corners will always have a radius, but external surfaces can have sharp edges and can be machined very thin.
Each 3D printing system offers a different dimensional accuracy. Industrial machines can produce parts with very good tolerances. If tight clearances are required, the critical dimensions can be 3D printed oversized, and then machined during post-processing.
The minimum wall thickness of 3D printed parts is restricted by the size of the end effector (to the nozzle diameter in FDM or the laser spot size in SLS). Since parts are fabricated one layer at a time, layer lines might be visible, especially on curved surfaces. The maximum part size is relatively small, as 3D printing often requires pretty strict environmental control.
Technology Tolerance Minimum wall thickness Maximum part size
CNC machining ± 0.025 - 0.125 mm* 0.75 mm Milling: 2000 x 800 x 1000 mm Lathe: Ø 500 mm
SLS ± 0.300 mm 0.7 - 1.0 mm 300 x 300 x 300 mm
FDM Desktop: ± 0.500 mm Industrial: ± 0.200 mm 0.8 - 1.0 mm Desktop: 200 x 200 x 200 mm Industrial: 900 x 600 x 900 mm
SLM/DMLS ± 0.100 mm 0.40 mm 230 x 150 x 150 mm
Binder jetting ± 0.200 mm 2.0 mm 380 x 355 x 735 mm
*According to the specified level of tolerance
Comparing materials: machining metals vs. printing plastics
3D printing and CNC machining both work with metals and plastics, though the two technologies don’t manipulate these materials equally.
CNC machining is mainly used to produce parts from metal. As it’s quite flexible, you can also use the CNC process to manufacture parts from thermoplastics, acrylics, softwoods and hardwoods, modeling foams and machining wax.
Material considerations for CNC machining
  • Great mechanical and thermal properties with fully isotropic behavior
  • Dimensional restrictions from blank size (using a non-standard blank size will increase the manufacturing cost)
What are the most common CNC materials?
3D printing is predominantly used to create parts using thermoplastics and thermosets, though you can print metal parts with some technologies. Several 3D printers can produce parts from ceramics, wax, sand, composites and a growing roster of bio-materials.
Material considerations for 3D printing
  • Wide variety of materials with a wide range of physical properties
  • Materials that are difficult to machine (TPU and metal superalloys) can be 3D printed
  • Potentially lesser mechanical properties compared to CNC parts, as they are typically not fully isotropic
What are the common 3D printing materials?
What's the best way to manufacture complex parts?
Part complexity is a major factor to consider when choosing between 3D printing and CNC machining. Both technologies have their share of design limitations, though CNC machines can produce far fewer geometries.
CNC machining involves several key design limitations, including tool access and clearances, hold or mount points, as well as the inability to machine square corners due to tool geometry. Some geometries are even impossible to manufacture with CNC, as the tools can’t access all surfaces of your part. This goes for 5-axis systems as well.
Most geometries require the operator to rotate the part so tools can access different sides and angles. Repositioning adds to the processing and labor time, and in some cases, jigs and fixtures are required. All of these factors will raise the final price of the part.
Compared to CNC, 3D printing can produce parts with very few geometric limitations. Support structures may be needed for processes like FDM, but a little extra post-processing doesn’t diminish the vast design freedom and capacity for complexity you get with 3D printing.
Plus, polymer-based powder bed fusion processes such as SLS and MJF can produce freeform, organic geometries without the need for support structures. The ability to produce highly complex geometries with relative ease is one of 3D printing’s key strengths.
CNC machines remove material on a point-by-point basis, though even 5-axis systems aren't always able to access some surfaces
Comparing manufacturing workflows for 3D printing and CNC machining
It’s important to understand the workflows for both types of manufacturing processes discussed in this article. Let’s break down the workflows for 3D printing and CNC machining.
CNC manufacturing tends to be a labor-intensive process. With CNC, the machine operator will first have to decide upon tool selection, spindle speed, cutting path and potential part repositioning. The operator will have to manually set up the block in the machine, keeping all these factors in mind. As well, it will be essential to know whether the component will be ready after machining or whether you’ll need one or several post-processing steps. All of these considerations will affect the quality of the component as well as its build time.
With 3D printing, the operator will first prepare the digital file, choosing orientation and adding supports if necessary. Then the file will go to the machine, where the printer does all the building work with little to no human intervention. When printing is complete, the part will need to be cleaned and go through post-processing. These last steps are the most labor-intensive parts of the 3D printing manufacturing workflow.
Comparing post-processing for 3D printing and CNC machining
There are many post-processing methods that can be applied to both 3D printing and CNC machining to improve the functional and cosmetic qualities of parts. Let’s cover the most common post-processing techniques.
What are the main post-processing methods for CNC & 3DP
  • CNC machining: Bead blasting, anodizing (Type II & Type III), powder coating
  • 3D printing: Media blasting, sanding & polishing, micro-polishing, metal plating
3DP vs CNC case study: what if you’re prototyping a plastic enclosure?
FDM 3D printers can produce low-cost prototypes for electronics enclosures
If you’re designing a new consumer electronics product, fabricating prototypes for the enclosure is a key step before you can start manufacturing at scale. Fast lead times and low cost are the main objectives for accelerating development time.
Enclosures for electronics often have snap fits, living hinges or other interlocking joints and fasteners. You can produce all of these features with FDM and SLS 3D printing or CNC machining.
CNC and SLS can be used to create high-accuracy and cosmetic prototypes, but FDM (we’re talking desktop here) has much shorter lead times and is cheaper. Since mechanical performance may not be the highest priority for this kind of project, the benefits of CNC and SLS are not usually worth the extra cost and time.
Factor CNC machining Desktop FDM SLS
Cost $$ $ $$
Common materials ABS, Nylon PLA, ABS, Nylon Nylon
Lead time 1-2 weeks 1-3 days Less than a week
Accuracy ± 0.125 mm ± 0.500 mm ± 0.300 mm
3DP vs CNC cast study: what if you’re manufacturing metal brackets and mechanical components?
Metal components with simple geometry manufactured with CNC machining and powder coated
Metal brackets and other mechanical components can bear heavy loads and operate at more extreme temperatures. If you’re producing these kinds of parts, your main objectives will likely be good material properties and dimensional accuracy.
CNC machining is the best option in terms of accuracy, cost and mechanical accuracy if the geometry of your model is simple (like the components of the image above).
When the geometric complexity increases or when you need to use less common materials, you may want to consider metal 3D printing. Components optimized for weight and strength (like the brackets of the image below) have organic structures that are very difficult and costly to machine with CNC systems.
Of course, you can combine CNC machining and metal 3D printing to manufacture parts with organic shapes and very tight tolerances at critical locations on the components.
Factor CNC machining CSLM/DMLS Binder Jetting
Cost $$ $$$$ $$$
Common materials Aluminum, stainless steel, brass Stainless steel, aluminum, titanium, Inconel, cobalt-chrome Stainless steel, Inconel, cobalt-chrome, Tungsten carbide
Accuracy ± 0.025 mm ± 0.100 mm ± 0.200 mm
Mechanical properties Very good Very good Good
Brackets manufactured in titanium with SLM (image courtesy of TU Delft's Formula Student Team)
Protolabs Network's top tips & tricks for choosing between 3D printing & CNC machining
Selecting the right manufacturing technology for your custom parts may feel like an insurmountable challenge, but it doesn't have to. We’ve put together a few essential rules of thumb to follow if you’re facing this decision.
  • Choose CNC machining if you are producing parts in medium to high quantities (250-500 parts) that have relatively simple geometries
  • Choose 3D printing for lower quantities of parts—or single prototypes—and if your designs have complex geometries
  • When considering metals, CNC can be price competitive even for low quantities, but geometry limitations still apply
  • If you’re printing more than 500 parts or so, maybe consider other technologies like injection molding (or a mix of 3DP or CNC and a forming process)
Model complexity and number of parts are key consideration for selecting the right manufacturing process
Curious about the costs of 3D printing and CNC machining?
Get a free, instant quote today
Is CNC machining better than 3D printing?
The short answer to this question is: it depends. CNC machines can produce parts with smoother surfaces than 3D-printed parts, and you probably want to go with CNC machining if you want your components to fit together with precision. 3D printing yields excellent parts for finish and fit, though the quality of both also depend on which type of 3D printer you’re using.
What’s the best 3D printing process for plastic parts?
For many prototyping and functional applications, we recommend using industrial FDM and SLS if you’re printing plastic parts.
What’s the best 3D printing process for metal parts?
SLM/DMLS and Binder Jetting are the two best options for producing functional parts and prototypes from metal materials.
Is 3D printing better than CNC machining for producing prototypes?
When it comes to cost and lead times (both essential in the prototyping phase of product development), 3D printing wins over CNC machining.
Will 3D printing make CNC machining obsolete?
3D printing hasn’t replaced CNC machining, more traditional subtractive methods or injection molding yet, but additive technology is advancing rapidly. You can now 3D print parts from a wider variety of materials, including some metals. However, for many applications, CNC machining is the better option.
ABS 3D printed part
What is CNC milling?
What is CNC milling and how does this subtractive manufacturing process work? This article explores how CNC milling machines work, what kinds of parts you can provide with milling and the best design practices for getting the most out of this type of CNC machining.
What is rapid prototyping?
Introduction to CNC machining
What is CNC machining?
Standard Drill Bit Sizes for CNC machining (Conversion Tables)
Standard drill bit sizes for CNC machining
Use these conversion tables of standard drill bit sizes (metric, fractional inch, and wire gauge) common in CNC machining to reduce manufacturing costs from custom tooling.
ABS 3D printed part
