How do you design enclosures for 3D printing?
Learn how to optimize the design of your enclosure for 3D printing, follow a step-by-step guide on the design process and review the most common enclosure materials.
Enclosure design for 3D Printing: A step-by-step guide
3D Printing of enclosures allows design freedom, lets a designer print a prototype or final part in a matter of hours and is much cheaper when compared to traditional manufacturing methods. 3D printed enclosures offer an effective method of confirming form and fit and several of the materials that can be used for printing enclosures are suitable for end use applications.
Assembled 3D printed enclosure for a DIY loudspeaker
This article will discuss the most common 3D printing technologies that are used to print enclosures, methods for securing printed enclosures together and introduce some design considerations to help optimize enclosure design for 3D printing.
3D printed enclosure technologies
The table below discuss the main 3D printing technologies and whether they are appropriate for a range of enclosure applications.
Application Description Printing Technology
Rapid prototyping Prototyping plastics are a cost effective and quick method of printing enclosures. FDM
High Temperature Heat resistant plastics are rated to remain stable up to temperatures as high as 80℃ after thermal post treatment. Material Jetting
High quality surface finish The selection of surface finish is usually governed by cost and time. SLS nylon results in a satin-like matte finish that is slightly grainy to the touch while Material Jetting and SLA offer fine-detail models with very smooth surfaces. Material Jetting
High accuracy SLS nylon, SLA and Material Jetting printed parts are highly accurate and are capable of printing to within 0.2 - 0.5 mm. They give an excellent surface finish. SLS nylon does no require any support while the support used for material jetting is typically dissolvable and easy to remove resulting in an smooth surface after post processing. SLA, SLS or Material Jetting
Transparent 3D printed transparent plastics allow for inspection or verification of internal components and are often applied to applications where fluids are being employed. SLA or material jetting
Flexible material Flexible enclosures allow the pressing of buttons or motion of switches through the sealed case. Rubber-Like plastics or SLA flexible resin
Curious about the cost of prototyping with 3D printing?
Upload your files here
Enclosures can be made from a range of different 3D printing materials like SLS (white), FDM (black) and SLA (gray) with each technology having benefits and limitations.
Securing enclosure assemblies
Snap fits, interlocking joints, threaded fasteners, and living hinges are all viable options for 3D printed enclosure connections. Designing snap-fits and push-fits for an enclosure that does not require repeated opening is much easier because the joint does not have to be as wear-resistant. For quick prototypes, adhesives are a quick and easy method to permanently fasten the enclosure.
Snap-fits are regularly used for securing 3D printed enclosures
Fastening with threaded fasteners is a durable and quick option for reliable repeated opening
Using living hinges in conjunction with snap fit connections can create a simple, quick way to secure 3D printed enclosures
Designing 3D printed enclosures
The design of enclosures for 3D printing typically follows 2 main steps:
1. Enclosure planning and component measurement
It can be useful to 3D model the internal enclosure components along with the enclosure to allow for easy clearance checks and to help determine the optimal component positions.
2. Designing the structure
While tolerance and clearance recommendations will vary with printer technology and calibration the bullet points below offer a set of design guideline to use:
Wall thickness A minimum wall thickness of 2 mm is recommended for all enclosure walls.
Add radii/fillets to corners Radii or fillets help to reduce stress concentrations at corner and edges and also make parts easier to 3D print. Even a small radius can make a big difference.
Component clearance Allow 0.5 mm around all internal components to compensate for distortion, shrinkage and printer tolerances. The accuracy 3D printers are able to produce parts varies by technology
Clearance holes Add 0.25 mm to the diameter of screw and fastener clearance holes. For more accurate clearance holes, drill the holes after printing.
Self taping holes Subtract 0.25 mm from the diameter of holes if you are wanting the screw or fastener to bite into the case. For a range of fasteners options refer to this article.
Port clearance For all ports or plugs allow 2 mm clearance (1mm each side). The input port can also be super glued into place for a secure connection.
Add lugs Add lugs, cut outs and lips to assist with assembly/disassembly and alignment if the enclosure with multiple parts (base & lid). These features are very simple to include in a design and can greatly increase the strength of your assembled enclosure. Lugs should be a minimum of 5mm in width.
Ribs and gussets While ribs and gussets are critical design features of injection molding and not essential for 3D printing their inclusion can help reduce and distribute stresses throughout the part and improve rigidity. To save on material, ribs and gussets can be designed to 75-80% of wall thickness.
Bosses Include bosses around holes in locations where threaded fasteners will be used to reduce the likelihood of bulging, distortion and potential fracture. A minimum of 1 hole diameter for the wall thickness around the hole is a good starting point (e.g. if the hole is for an M5 screw include a minimum 5mm of wall thickness around the hole).
Uniform wall thickness If your enclosure design is eventually going to be injection molded remember to use uniform wall thickness in your design. For 3D printing process (particularly SLS and SLA) this is good design practice.
Rules of thumb
  • For enclosures that will experience repeated opening and closing a wear-resistant material such as SLS nylon. For rapid prototypes where form or fit are being tested FDM provides a fast low-cost method of production.
  • If the enclosure will be subjected to loads include gussets, ribs, and bosses to improve strength
  • A minimum wall thickness of 2 mm, 0.5 mm tolerance around internal components and ± 0.25 mm for clearance/bite holes are good start points to consider when designing a 3D printed enclosure.
3D Modeling CAD Software
How to design parts for metal 3D printing
A comprehensive guide for metal 3D printing covering the printing process, design specifications, material options and technology limitations.
Jewelry 3D Printing Applications
Jewelry 3D printing applications
This article discusses how 3D printing is being used to produce high detail, custom jewelry through investment casting and direct metal printing.
