Written by Agata Lovrecich, Product Manager at 3D Hubs
At university we learn how to design parts to optimize design efficiency - less material, higher performance. In the real world the details, such as threads, can cause you to waste time and lose money.
There is little practical literature targeting threads in the context of design for manufacturing. Most articles you will find talk about the actual machining of the parts and are catered towards machinists. This article seeks to be a practical guide for engineers designing physical products.
Threads can be either internal or external and typically fit together. They are called out (or specified) in a technical drawing by defining the following parameters.
There are two types of holes where you can define threads: blind holes and thru holes.
There are various different thread types available, the most common are metric and unified.
The following threads are the simplest type of threads and are understood by both local and global suppliers. The dimensions should be placed on the view that describes the feature most clearly.
As a standard, you can define metric threads by simply putting the type and size (e.g. M10). The size, as mentioned above, is defined by the nominal diameter (major diameter) of the thread. The pitch and depth that follow will follow the common metric common standards (see table below).
All metric threads are assumed to be “thru” on thru holes unless indicated otherwise. Depths for blind holes must always be indicated.
Examples: Standard ISO thread: M10 x 1.5 - 6H THRU RH Standard ISO thread: M10
Drill size = Hole size required
Size | Drill size | Drill size, decimal size equivalent | Thread type |
0-80 | 3/64" | 0.0469" | UNF |
1-64 | 53 ga. | 0.0595" | UNC |
1-72 | 53 ga. | 0.0595" | UNF |
2-56 | 51 ga. | 0.067" | UNC |
2-64 | 50 ga. | 0.07" | UNF |
3-48 | 47 ga. | 0.0785" | UNC |
3-56 | 46 ga. | 0.081" | UNF |
4-40 | 43 ga. | 0.089" | UNC |
4-48 | 42 ga. | 0.0935" | UNF |
5-40 | 38 ga. | 0.1015" | UNC |
5-44 | 37 ga. | 0.104" | UNF |
6-32 | 36 ga. | 0.1065" | UNC |
6-40 | 33 ga. | 0.113" | UNF |
8-32 | 29 ga. | 0.136" | UNC |
8-36 | 29 ga. | 0.136" | UNF |
10-24 | 25 ga. | 0.1495" | UNC |
10-32 | 21 ga. | 0.159" | UNF |
12-24 | 16 ga. | 0.177" | UNC |
12-28 | 15 ga. | 0.18" | UNF |
1/4"-20 | 7 ga. | 0.201" | UNC |
1/4"-28 | 3 ga. | 0.213" | UNF |
1/4"-32 | 5.6 mm | 0.2204" | UNEF |
5/16"-18 | F | 0.257" | UNC |
5/16"-24 | I | 0.272" | UNF |
5/16"-32 | 9/32" | 0.2813" | UNEF |
3/8"-16 | 5/16" | 0.3125" | UNC |
3/8"-24 | Q | 0.332" | UNF |
3/8"-32 | 11/32" | 0.3438" | UNEF |
7/16"-14 | U | 0.368" | UNC |
7/16"-20 | 25/64" | 0.3906" | UNF |
7/16"-28 | 13/32" | 0.4063" | UNEF |
1/2"-13 | 27/64" | 0.4219" | UNC |
1/2"-20 | 29/64" | 0.4531" | UNF |
1/2"-28 | 15/32" | 0.4688" | UNEF |
9/16"-12 | 31/64" | 0.4844" | UNC |
9/16"-18 | 33/64" | 0.5156" | UNF |
9/16"-24 | 33/64" | 0.5156" | UNEF |
5/8"-11 | 17/32" | 0.5313" | UNC |
5/8"-18 | 37/64" | 0.5781" | UNF |
5/8"-24 | 37/64" | 0.5781" | UNEF |
11/16"-24 | 16.5 mm | 0.6496" | UNEF |
3/4"-10 | 21/32" | 0.6563" | UNC |
3/4"-16 | 11/16" | 0.6875" | UNF |
3/4"-20 | 45/64" | 0.7031" | UNEF |
7/8"-9 | 49/64" | 0.7656" | UNC |
7/8"-14 | 13/16" | 0.8125" | UNF |
7/8"-20 | 53/64" | 0.8281" | UNEF |
15/16"-20 | 57/64" | 0.8906" | UNEF |
1"-8 | 7/8" | 0.875" | UNC |
1"-12 | 59/64" | 0.9219" | UNF |
1"-20 | 61/64" | 0.9531" | UNEF |
1 1/8"-7 | 63/64" | 0.9844" | UNC |
1 1/8"-12 | 1 1/32" | 1.0313" | UNF |
1 1/4"-7 | 1 3/32" | 1.0938" | UNC |
1 1/4"-12 | 1 11/64" | 1.1719" | UNF |
1 1/4"-18 | 1 3/16" | 1.1875" | UNEF |
1 3/8"-6 | 1 7/32" | 1.2188" | UNC |
1 3/8"-12 | 1 19/64" | 1.2969" | UNF |
1 1/2"-6 | 1 11/32" | 1.3438" | UNC |
1 1/2"-12 | 1 27/64" | 1.4219" | UNF |
Size | Pitch, mm | Drill size | Thread type Coarse/Fine |
M1.6 | 0.35 | 1.25 mm | C |
M1.8 | 0.35 | 1.45 mm | C |
M2 | 0.4 | 1.6 mm | C |
M2.2 | 0.45 | 1.75 mm | C |
M2.5 | 0.45 | 2.05 mm | C |
M3 | 0.5 | 2.5 mm | C |
M3.5 | 0.6 | 2.9 mm | C |
M4 | 0.7 | 3.3 mm | C |
M4 | 0.75 | 3.2 mm | F |
M4.5 | 0.75 | 3.7 mm | C |
M5 | 0.5 | 4.5 mm | F |
M5 | 0.8 | 4.2 mm | C |
M6 | 0.5 | 5.5 mm | F |
M6 | 0.75 | 5.2 mm | F |
M6 | 1 | 5 mm | C |
M6.3 | 1 | 5.3 mm | F |
M7 | 1 | 6 mm | C |
M8 | 0.5 | 7.5 mm | F |
M8 | 0.75 | 7.2 mm | F |
M8 | 1 | 6.9 mm | F |
M8 | 1.25 | 6.7 mm | C |
M9 | 1 | 8 mm | F |
M9 | 1.25 | 7.7 mm | C |
M10 | 1 | 8.9 mm | F |
M10 | 1.25 | 8.7 mm | F |
M10 | 1.5 | 8.5 mm | C |
M11 | 1 | 10 mm | F |
M11 | 1.5 | 9.5 mm | C |
M12 | 1 | 11 mm | F |
M12 | 1.25 | 10.8 mm | F |
M12 | 1.5 | 10.5 mm | F |
M12 | 1.75 | 10.2 mm | C |
M14 | 1 | 13 mm | F |
M14 | 1.25 | 12.8 mm | F |
M14 | 1.5 | 12.5 mm | F |
M14 | 2 | 12 mm | C |
M16 | 1 | 15 mm | F |
M16 | 1.5 | 14.5 mm | F |
M16 | 2 | 14 mm | C |
M18 | 1 | 17 mm | F |
M18 | 1.5 | 16.5 mm | F |
M18 | 2.5 | 15.5 mm | C |
M20 | 1 | 19 mm | F |
M20 | 1.5 | 47/64" | F |
M20 | 2.5 | 17.5 mm | C |
M22 | 1.5 | 20 mm | F |
M22 | 2.5 | 25/32" | F |
M24 | 1.5 | 57/64" | F |
M24 | 2 | 22 mm | F |
M24 | 3 | 21 mm | C |
M26 | 1.5 | 24.5 mm | F |
M27 | 1.5 | 1" | F |
M27 | 2 | 25 mm | F |
M27 | 3 | 24 mm | C |
M30 | 1.5 | 1 1/8" | F |
M30 | 2 | 28 mm | F |
M30 | 3.5 | 1 1/32" | C |
M33 | 2 | 31 mm | F |
M33 | 3.5 | 1 11/64" | C |
M35 | 1.5 | 33.5 mm | F |
M36 | 1.5 | 34.5 mm | F |
M36 | 2 | 34 mm | F |
M36 | 4 | 32 mm | C |
00-90 | 62 ga. | 0.038" | UNS |
6-48 | 2.9 mm | 0.1142" | UNS |
8-24 | 31 ga. | 0.12" | UNS |
8-40 | 28 ga. | 0.1405" | UNS |
10-28 | 23 ga. | 0.154" | UNS |
10-36 | 20 ga. | 0.161" | UNS |
10-40 | 20 ga. | 0.161" | UNS |
10-48 | 18 ga. | 0.1695" | UNS |
10-56 | 18 ga. | 0.1695" | UNS |
12-36 | 12 ga. | 0.189" | UNS |
3/16"-24 | 9/64" | 0.147" | UNS |
3/16"-100 | 16 ga. | 0.177" | UNS |
7/32"-32 | 13 ga. | 0.185" | UNS |
1/4"-24 | 4 ga. | 0.209" | UNS |
1/4"-27 | 3 ga. | 0.213" | UNS |
1/4"-36 | 2 ga. | 0.221" | UNS |
1/4"-40 | 2 ga. | 0.221" | UNS |
1/4"-48 | 1 ga. | 0.228" | UNS |
1/4"-56 | 1 ga. | 0.228" | UNS |
1/4"-80 | B | 0.238" | UNS |
9/32"-32 | 1/4" | 0.25" | UNS |
5/16"-20 | G | 0.261" | UNS |
5/16"-27 | 6.9 mm | 0.2716" | UNS |
5/16"-28 | J | 0.277" | UNS |
5/16"-40 | 7.2 mm | 0.2834" | UNS |
11/32"-32 | 5/16" | 0.3125" | UNS |
3/8"-18 | 8.1 mm | 0.3188" | UNS |
3/8"-20 | 8.2 mm | 0.3228" | UNS |
3/8"-27 | R | 0.339" | UNS |
3/8"-28 | R | 0.339" | UNS |
3/8"-40 | 8.9 mm | 0.3503" | UNS |
7/16"-16 | 9.5 mm | 0.374" | UNS |
7/16"-18 | 9.6 mm | 0.3779" | UNS |
7/16"-24 | 9.9 mm | 0.3897" | UNS |
7/16"-27 | 10.2 mm | 0.4015" | UNS |
7/16"-32 | 13/32" | 0.4063" | UNS |
7/16"-40 | 10.5 mm | 0.4134" | UNS |
15/32"-32 | 7/16" | 0.4375" | UNS |
1/2"-12 | 10.5 mm | 0.4134" | UNS |
1/2"-16 | 7/16" | 0.4375" | UNS |
1/2"-18 | 11.2 mm | 0.4409" | UNS |
1/2"-24 | 11.5 mm | 0.4528" | UNS |
1/2"-27 | 11.5 mm | 0.4528" | UNS |
1/2"-32 | 15/32" | 0.4688" | UNS |
1/2"-40 | 12 mm | 0.4724" | UNS |
9/16"-16 | 1/2" | 0.5" | UNS |
9/16"-20 | 33/64" | 0.5156" | UNS |
9/16"-27 | 33/64" | 0.5156" | UNS |
9/16"-32 | 17/32" | 0.5313" | UNS |
5/8"-12 | 35/64" | 0.5469" | UNS |
5/8"-16 | 9/16" | 0.5625" | UNS |
5/8"-20 | 37/64" | 0.5781" | UNS |
5/8"-27 | 37/64" | 0.5781" | UNS |
5/8"-28 | 37/64" | 0.5781" | UNS |
5/8"-32 | 19/32" | 0.5938" | UNS |
11/16"-16 | 5/8" | 0.625" | UNS |
11/16"-18 | 16 mm | 0.6299" | UNS |
11/16"-20 | 41/64" | 0.6406" | UNS |
11/16"-32 | 21/32" | 0.6563" | UNS |
3/4"-12 | 16.5 mm | 0.6496" | UNS |
3/4"-18 | 45/64" | 0.7031" | UNS |
3/4"-24 | 45/64" | 0.7031" | UNS |
3/4"-27 | 23/32" | 0.7188" | UNS |
3/4"-32 | 23/32" | 0.7188" | UNS |
13/16"-12 | 47/64" | 0.7344" | UNS |
13/16"-16 | 3/4" | 0.75" | UNS |
13/16"-18 | 19 mm | 0.748" | UNS |
7/8"-12 | 51/64" | 0.7969" | UNS |
7/8"-16 | 13/16" | 0.8125" | UNS |
7/8"-18 | 53/64" | 0.8281" | UNS |
7/8"-27 | 21 mm | 0.8268" | UNS |
7/8"-32 | 27/32" | 0.8438" | UNS |
15/16"-16 | 7/8" | 0.875" | UNS |
1"-14 | 23.5 mm | 0.9252" | UNS |
1"-16 | 15/16" | 0.9375" | UNS |
1"-18 | 61/64" | 0.9531" | UNS |
1"-24 | 61/64" | 0.9531" | UNS |
1"-27 | 24.5 mm | 0.9646" | UNS |
1"-32 | 31/32" | 0.9688" | UNS |
Header | Header | Header | Header |
Cell | Cell | Cell | Cell |
Pipe size | Thread type | TPI | Drill size | Drill size, decimal size equivalent |
1/16 | NPT | 27 | C | 0.242" |
1/8 | NPT | 27 | Q | 0.332" |
1/4 | NPT | 18 | 7/16" | 0.4375" |
3/8 | NPT | 18 | 9/16" | 0.5625" |
1/2 | NPT | 14 | 45/64" | 0.7031" |
3/4 | NPT | 14 | 29/32" | 0.9063" |
1 | NPT | 11 1/2 | 1 9/64" | 1.1406" |
1 1/4 | NPT | 11 1/2 | 1 31/64" | 1.4844" |
1 1/2 | NPT | 11 1/2 | 1 23/32" | 1.7188" |
2 | NPT | 11 1/2 | 2 3/16" | 2.1875" |
1/8 | NPS | 27 | T | 0.358" |
1/4 | NPS | 18 | 15/32" | 0.4688" |
3/8 | NPS | 18 | 19/32" | 0.5938" |
1/2 | NPS | 14 | 19 mm | 0.748" |
3/4 | NPS | 14 | 61/64" | 0.9531" |
1 | NPS | 11 1/2 | 1 13/64" | 1.2031" |
1/8 | BSPP | 28 | 8.8 mm | 0.3464" |
1/4 | BSPP | 19 | 11.8 mm | 0.4645" |
3/8 | BSPP | 19 | 15 mm | 0.5905" |
1/2 | BSPP | 14 | 19 mm | 0.748" |
3/4 | BSPP | 14 | 24 mm | 0.9449" |
1 | BSPP | 11 | 30 mm | 1.1811" |
1 1/4 | BSPP | 11 | 39.5 mm | 1.5551" |
1 1/2 | BSPP | 11 | 45 mm | 1.7716" |
2 | BSPP | 11 | 57 mm | 2.244" |
1/8 | BSPT | 28 | 8.4 mm | 0.3307" |
1/4 | BSPT | 19 | 11.2 mm | 0.4409" |
3/8 | BSPT | 19 | 14.5 mm | 0.5709" |
1/2 | BSPT | 14 | 18 mm | 0.7087" |
3/4 | BSPT | 14 | 22 mm | 0.8661" |
1 | BSPT | 11 | 30 mm | 1.1811" |
1 1/4 | BSPT | 11 | 38.5 mm | 1.5157" |
1 1/2 | BSPT | 11 | 44.5 mm | 1.7519" |
2 | BSPT | 11 | 56 mm | 2.2047" |
Pipe size | Thread type | Drill size | Drill size, decimal size equivalent |
PG-7 | PG | 11.2 mm | 0.4409" |
PG-9 | PG | 35/64" | 0.5468" |
PG-11 | PG | 17.25 mm | 0.6791" |
PG-13.5 | PG | 3/4" | 0.75" |
PG-16 | PG | 21.25 mm | 0.8366" |
PG-21 | PG | 1 1/16" | 1.0625" |
PG-29 | PG | 1 13/32" | 1.4063" |
PG-36 | PG | 1 51/64" | 1.7969" |
Examples:
If there’s one thing that will without fail save you time and money when it comes to manufacturing is to keep things common.
You don’t learn this when you’re getting your degree, and it's only through trial and error that seasoned engineers realise the importance of keeping components as common as possible - even when designing custom products. If there’s an off the shelf solution, don’t over complicate it. This also applies to threads, always seek to choose common series of threads as much as possible and common sizes.
By common I mean globally understood. We know that there are threads such as NPT, BSP, etc. that are also common locally but overseas suppliers tend to have issues with these unless they're specialized. I suggest to always make design choices that maximize the amount of manufacturers eligible to supply them. Why? Because having a diversified supply mitigates risks and gives you more buying power.
One of the most common mistakes we’ve seen when we make parts containing threads (we’ve manufactured more than 6 million parts at the time of writing) is that the thread sizes do not seem to match the hole sizes they are called out in.
This is a problem because it leads to confusion on whether it’s the right thread size and the diameter of the hole is wrong or vice-versa. As manufacturers, we cannot make assumptions, and this confusion leads to a delay in manufacturing time (1-2 days at least).
Another reason for delay is incomplete thread specifications.
Blind holes are holes that do not go through the full wall thickness of the part. If you call out a thread on a blind hole, you must always indicate the depth of the thread.
About the author
Agata is a Product Manager at 3D Hubs responsible for the manufacturing service offering. Having worked with multiple customers and suppliers, Agata has an excellent understanding of the common hiccups in custom manufacturing. She holds an Aerospace Engineering Bachelors and a Masters in Innovation Management. |
