Which FDM 3D Printing plastic is best for my application?
3d Matter
Compare the main FDM 3D printing plastics - PLA, ABS, PET, Nylon, TPU (Flexible) and PC - by material properties and find the best option for your application.
Choosing the right type of material to print a given object is becoming increasingly difficult as the 3D printing market sees the regular emergence of radically new materials. In FDM 3D printing, PLA and ABS have historically been the two main polymers used, but their initial dominance was mostly fortuitous, so there should not be any major road blocks for other polymers to play a key role in the future of FDM.
We are now seeing new products become more popular, both pure polymers and composites. In this study, we focus on the main pure polymers that exist in the market today: PLA, ABS, PET, Nylon, TPU (Flexible) and PC. We sum up the key differences between their properties in snapshot profiles, so that users can make a quick decision about the best polymer to use for their application.
Methodology
Materials are usually graded along 3 categories: mechanical performance, visual quality and process. In this case here, we decided to further break down these categories to paint a clearer picture of the polymer’s properties. The choice of material really depends on what the user wants to print, so we listed the key decision criteria needed to choose a material (other than cost and speed):
A spider web graph showing the material properties that will be compared
  • Ease of printing: How easy it is to print a material: bed adhesion, max printing speed, frequency of failed prints, flow accuracy, ease to feed into the printer etc.
  • Visual quality: How good the finished object look. More info on how we test it here
  • Max stress: Maximum stress the object can undergo before breaking when slowly pulling on it.
  • Elongation at break: Maximum length the object has been stretched before breaking.
  • Impact resistance: Energy needed to break an object with a sudden impact.
  • Layer adhesion (isotropy): how good the adhesion between layers of material is. It is linked to “isotropy” (=uniformity in all directions): the better the layer adhesion, the more isotropic the object will be.
  • Heat resistance: max temperature the object can sustain before softening and deforming.
We are also providing additional information that are not captured in the diagram, for one of two reasons:
  • They are neither “good” nor “bad” in essence, they are just properties that will be suitable for some applications, and not for others, such as rigidity.
  • We don’t have a good quantitative assessment of it, but we know it is an important factor, such as humidity resistance or toxicity.
Results
We ranked each material along each criteria on a 1 (low) to 5 (high) scale. These are relative grades for the FDM process, they would probably look quite different if other manufacturing technologies were taken into account. Using the data from Optimatter we ranked the polymers along the different criteria considered:
The research results for all six polymers displayed in one graph.
PLA
PLA is the easiest polymer to print and provides good visual quality. It is very rigid and actually quite strong, but is very brittle.
The material profile of PLA
Pros Cons
Biosourced, biodegradable Low humidity resistance
Odorless Can't be glued easily
Can be post-processed with sanding paper and painted with acrylics
Good UV resistance
Other pros and cons to consider for PLA
ABS is usually picked over PLA when higher temperature resistance and higher toughness is required.
The material profile of ABS
Pros Cons
Can be post-processed with acetone vapors for a glossy finish UV sensitive
Can be post-processed with sanding paper and painted with acrylics Odor when printing
Acetone can also be used as strong glue Potentially high fume emissions
Good abrasion resistance
Other pros and cons to consider for ABS
PET
PET is a slightly softer polymer that is well rounded and possesses interesting additional properties with few major drawbacks.
The material profile of PET
Pros Cons
Food safe (FDA approved)
High humidity resistance
High chemical resistance
Recyclable
Good abrasion resitance
Can be post-processes with sanding paper and painted with acrylics
Can be glued
Other pros and cons to consider for PET
Nylon possesses great mechanical properties, and in particular the best impact resistance for a non-flexible filament. Layer adhesion can be an issue however.
The material profile of Nylon
Pros Cons
Good chemical resistance Very low humidity resistance
Other pros and cons to consider for Nylon
TPU
TPU is mostly used for flexible applications, but its very high impact resistance can open other applications.
The material profile of TPU
Pros Cons
Good abrasion resistance Difficult to post process
Good resistance to oil and grease Can't be glued easily
Other pros and cons to consider for TPU
PC
PC is the strongest material of all, and can be an interesting alternative to ABS as the properties are quite similar.
The material profile of PC
Pros Cons
Can be sterilized UV sensitive
Easy to post-process (sanding)
Other pros and cons to consider for PC
Conclusion
Choosing the right polymer is critical to get the right properties for a 3D printed part, especially if the part has a functional use. This article will help users find the right material depending on the properties they need. However, material suppliers also often provide blends or add additives to modify the properties of the pure polymer (e.g. adding carbon fiber to make the material stiffer). We are not addressing these more complex formulations in this article, but you can find data on some of these products in our optimization tool at OptiMatter.
Disclaimer
  • The grades given in this article are for an average polymer representing the general chemistry, but the performance will vary depending on the actual product or supplier the user buys from.
  • All the data underlying our grades in this study was measured by 3D Matter, with the exception of Heat Resistance, for which we used the glass temperature given by multiple filament suppliers.
  • For the sections called “Additional considerations”, we are using a combination of third-party assessments and of our own observations.
  • The Nylon type we are talking about in this article is Nylon 6, not Nylon 11 or 12.
  • Visual quality is tested without any significant post-processing. There are ways to smoothen the prints and improve the visual quality of a given polymer significantly (e.g. using acetone vapor on ABS).
  • The toxicity of 3D printing polymers is still not very well understood, and is a factor that might play a bigger role in the future. We are basing our comments regarding toxicity on one study by Azimi et al. [1]
[1] Azimi et al, Emissions of Ultrafine Particles and Volatile Organic Compounds from Commercially Available Desktop Three-Dimensional Printers with Multiple Filaments, Environmental Science & Technology, 2016
A big thank you to 3D Matter for sharing this material research with our community.
3D Matter is a material specialist bringing 3D printing users closer to material science. We conduct research on 3D printed materials, measuring their mechanical performance, visual quality and processability. With the extensive data collected, 3D Matter has developed OptiMatter, a model that predicts the properties of printed parts. With OptiMatter, 3D printing users choose the best materials...
